Ana içeriğe geç
Asus Zenbook UX303L Speaker Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: adım 2, 1 resimden 1.
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: adım 4, 1 resimden 1.
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: adım 5, 1 resimden 1.
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: adım 6, 1 resimden 1.
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: adım 7, 1 resimden 1.
    • Carefully peel away the defective speakers from the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Snow
202 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Harley Spring 2019 IUPUI, Team S1-G6, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S1G6
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Is the Asus UX303L same as U303L?
Michael Wolf - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 1,795
