Ana içeriğe geç
Asus Zenbook UX303L Trackpad Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX303L Trackpad Replacement, Trackpad: adım 1, 1 resimden 1.
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Trackpad Replacement: adım 2, 3 resimden 1. Asus Zenbook UX303L Trackpad Replacement: adım 2, 3 resimden 2. Asus Zenbook UX303L Trackpad Replacement: adım 2, 3 resimden 3.
    • Remove all nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Trackpad Replacement: adım 3, 1 resimden 1.
    • Remove five Phillips #1 screws from the battery pack.
  4. Asus Zenbook UX303L Trackpad Replacement: adım 4, 3 resimden 1. Asus Zenbook UX303L Trackpad Replacement: adım 4, 3 resimden 2. Asus Zenbook UX303L Trackpad Replacement: adım 4, 3 resimden 3.
    • Unhook the red, black, and white coiled switch.
    • Detach the positive and negative red, black, yellow, and white switch from the motherboard.
    • Unhook the black and white coiled wire from the top of the battery pack.
  5. Asus Zenbook UX303L Trackpad Replacement: adım 5, 3 resimden 1. Asus Zenbook UX303L Trackpad Replacement: adım 5, 3 resimden 2. Asus Zenbook UX303L Trackpad Replacement: adım 5, 3 resimden 3.
    • Remove the three screws connecting the SSD to the motherboard.
    • Gently lift and pull out the SSD.
  6. Asus Zenbook UX303L Trackpad Replacement: adım 6, 3 resimden 1. Asus Zenbook UX303L Trackpad Replacement: adım 6, 3 resimden 2. Asus Zenbook UX303L Trackpad Replacement: adım 6, 3 resimden 3.
    • Remove the screw attaching the cooling fan to the motherboard.
    • Lift and remove the cooling fan.
  7. Asus Zenbook UX303L Trackpad Replacement: adım 7, 2 resimden 1. Asus Zenbook UX303L Trackpad Replacement: adım 7, 2 resimden 2.
    • Remove the four Phillips #1 screws attached to the black covered copper bar next to the cooling fan.
    • Gently lift and remove the copper bar.
  8. Asus Zenbook UX303L Trackpad Replacement: adım 8, 3 resimden 1. Asus Zenbook UX303L Trackpad Replacement: adım 8, 3 resimden 2. Asus Zenbook UX303L Trackpad Replacement: adım 8, 3 resimden 3.
    • Remove the silver tape to reveal the fourth screw on the motherboard.
    • Detach the motherboard by removing the four Phillips #1 screws.
    • Detach the white wire connecting the motherboard by lifting the black flap and pulling it out.
  9. Asus Zenbook UX303L Trackpad Replacement: adım 9, 1 resimden 1.
    • By using ESD-safe tweezers, remove the gray colored wire.
    • Remove the white wire using tweezers.
    • Remove the blue colored wire by lifting the black flap and pulling the blue flap out.
  10. Asus Zenbook UX303L Trackpad Replacement: adım 10, 3 resimden 1. Asus Zenbook UX303L Trackpad Replacement: adım 10, 3 resimden 2. Asus Zenbook UX303L Trackpad Replacement: adım 10, 3 resimden 3.
    • Remove the white wire with the blue ends by lifting the black flap with tweezers and gently pulling out.
    • Gently remove the silver tape using tweezers.
    • Remove the Phillips #1 screws.
  11. Asus Zenbook UX303L Trackpad Replacement: adım 11, 2 resimden 1. Asus Zenbook UX303L Trackpad Replacement: adım 11, 2 resimden 2.
    • Place the plastic opening tools under the trackpad.
    • Gently pull out and remove the trackpad.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Fredis Benitez
259 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
This laptop comes with a very bad trackpad, it has very low resolution. Do you think it can be updated?
eduugr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 5,859
