Ana içeriğe geç
Asus Zenbook UX31A Touchpad Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX31A Touchpad Replacement, Battery: adım 1, 2 resimden 1. Asus Zenbook UX31A Touchpad Replacement, Battery: adım 1, 2 resimden 2.
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Touchpad Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Touchpad Replacement: adım 3, 1 resimden 1.
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Touchpad Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Touchpad Replacement, Touchpad: adım 5, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove all four 6 mm screws from the trackpad.
  6. Asus Zenbook UX31A Touchpad Replacement: adım 6, 1 resimden 1.
    • Use your fingers or a nylon spuder to gently lift the track pad ZIF tab, and pull the ribbon cable free.
    • Be gentle with this wire since it is fragile
  7. Asus Zenbook UX31A Touchpad Replacement: adım 7, 1 resimden 1.
    • Lift up and pull backwards to remove the touchpad
Sonuç
Christopoher Orser
294 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G1
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 1,024
