Ana içeriğe geç
Asus Zenbook UX31A Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 2 resimden 1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 2 resimden 2.
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: adım 2, 2 resimden 1. Asus Zenbook UX31A Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
Sonuç
Sherwin
209 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 üyesi
UMASSD-SINCLAIRE-S22S7G1
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 22
Her zaman: 409
