Ana içeriğe geç
Asus Zenbook UX31E Fan Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Fan Replacement: adım 2, 1 resimden 1.
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: adım 3, 2 resimden 1. Asus Zenbook UX31E Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  4. Asus Zenbook UX31E Fan Replacement: adım 4, 1 resimden 1.
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: adım 5, 2 resimden 1. Asus Zenbook UX31E Fan Replacement: adım 5, 2 resimden 2.
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: adım 6, 2 resimden 1. Asus Zenbook UX31E Fan Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
Sonuç
Sinh
101 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-2, Rose Winter 2017 UW Tacoma, Team 1-2, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G2
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,742
