Ana içeriğe geç
Asus Zenbook UX32VD HD Web Camera Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: adım 1, 1 resimden 1.
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 2, 3 resimden 1. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 2, 3 resimden 2. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 2, 3 resimden 3.
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 3, 3 resimden 1. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 3, 3 resimden 2. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 3, 3 resimden 3.
    • Remove display screen frame completely before adhesive cools and hardens.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 4, 2 resimden 1. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 4, 2 resimden 2.
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 5, 3 resimden 1. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 5, 3 resimden 2. Asus Zenbook UX32VD  HD Web Camera Replacement: adım 5, 3 resimden 3.
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Michael Remmel
718 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G2
4 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - Yanıt Paylaş
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 2,334
