Ana içeriğe geç
Asus Zenbook UX32VD Battery Replacement
Neye ihtiyacın var
    1. Asus Zenbook UX32VD Battery Replacement, Bottom Panel: adım 1, 3 resimden 1. Asus Zenbook UX32VD Battery Replacement, Bottom Panel: adım 1, 3 resimden 2. Asus Zenbook UX32VD Battery Replacement, Bottom Panel: adım 1, 3 resimden 3.
      Bu adımda kullanılan alet:
      T5 Torx Screwdriver
      $9.99
      FixBot'a Sor
      Yorum Ekle
    2. Asus Zenbook UX32VD Battery Replacement: adım 2, 3 resimden 1. Asus Zenbook UX32VD Battery Replacement: adım 2, 3 resimden 2. Asus Zenbook UX32VD Battery Replacement: adım 2, 3 resimden 3.
      • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
      • Remove the bottom panel from the body of the laptop.
      • Set aside the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Zenbook UX32VD Battery Replacement, Battery: adım 3, 2 resimden 1. Asus Zenbook UX32VD Battery Replacement, Battery: adım 3, 2 resimden 2.
      • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Zenbook UX32VD Battery Replacement: adım 4, 2 resimden 1. Asus Zenbook UX32VD Battery Replacement: adım 4, 2 resimden 2.
      • Pry up each side of the flat connectors by hand or with a plastic opening tool.
      • Lift the connector straight up from its socket.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Zenbook UX32VD Battery Replacement: adım 5, 3 resimden 1. Asus Zenbook UX32VD Battery Replacement: adım 5, 3 resimden 2. Asus Zenbook UX32VD Battery Replacement: adım 5, 3 resimden 3.
      • Unplug the two bundled cable connectors on each side of the battery.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Zenbook UX32VD Battery Replacement: adım 6, 1 resimden 1.
      • Remove the battery completely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jenny Nguy
180 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G2
4 Üyeler
42 adet Kılavuz yazıldı
5Kılavuz Yorumları
what is the color code of the battery wiring? especially for the white and yellow
Asim Ahmed - Yanıt Paylaş
Will this method also apply to ASUS Zenbook UX430UQ ?
Kurt Scheel - Yanıt Paylaş
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Nikolay Em - Yanıt Paylaş
Why would you replace the speakers? I don't ever understand, why would you unplug the speakers (as it's done in these instructions)? They are just taped on side of the battery, once you lift up the battery a little bit, you can take the speakers off from the battery pack and leave them on their place while replacing the battery.
Touko Korpela - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 59
Her zaman: 18,878
