Giriş
Use this guide to replace old batteries in your Asus Zenbook UX32VD to get longer battery life!
Neye ihtiyacın var
Bu adımda kullanılan alet:T5 Torx Screwdriver$9.99
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Unplug the two bundled cable connectors on each side of the battery.
Pull the cable away from the connector in the same direction as the individual wires are running.
Unnecessary step. Just detach the speakers from the sides of the actual battery and leave them to the computer with wires connected. They are just attached with some 2-sided tape, easy to remove when you lift up the battery just a bit.
Also, if you decide to remove the speakers, the connectors should not be detached by pulling from the wires, the force should be applied directly to the connector with proper tool.
Remove the battery completely.
Battery replacement is pretty easy procedure for Asus Zenbook series. You also can check on my video how to replace the motherboard, which is more complex, but can be accomplished with mid level of experience.. https://www.youtube.com/watch?v=jJLl5DhY...
Even the video is for another model, you still can apply the same technique to another models from Zenbook series.
4 farklı kişi bu kılavuzu tamamladı.
5 Yorum
what is the color code of the battery wiring? especially for the white and yellow
Will this method also apply to ASUS Zenbook UX430UQ ?
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Why would you replace the speakers? I don't ever understand, why would you unplug the speakers (as it's done in these instructions)? They are just taped on side of the battery, once you lift up the battery a little bit, you can take the speakers off from the battery pack and leave them on their place while replacing the battery.
