Ana içeriğe geç
Asus Zenbook UX32VD GPU Fan Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: adım 1, 3 resimden 1. Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: adım 1, 3 resimden 2. Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    T5 Torx Screwdriver
    $9.99
    Satın Al
  2. Asus Zenbook UX32VD GPU Fan Replacement: adım 2, 3 resimden 1. Asus Zenbook UX32VD GPU Fan Replacement: adım 2, 3 resimden 2. Asus Zenbook UX32VD GPU Fan Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD GPU Fan Replacement, Fan: adım 3, 3 resimden 1. Asus Zenbook UX32VD GPU Fan Replacement, Fan: adım 3, 3 resimden 2. Asus Zenbook UX32VD GPU Fan Replacement, Fan: adım 3, 3 resimden 3.
    Spudger
    $2.99
    Satın Al
    • Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
    • Be sure to pry up on the hinged retaining flap, not the connector itself.
    • Remove the metallic ribbon cable from the connector .
    • No force is needed to remove or insert the cable.
  4. Asus Zenbook UX32VD GPU Fan Replacement: adım 4, 3 resimden 1. Asus Zenbook UX32VD GPU Fan Replacement: adım 4, 3 resimden 2. Asus Zenbook UX32VD GPU Fan Replacement: adım 4, 3 resimden 3.
    Phillips #0 Screwdriver
    $5.49
    Satın Al
  5. Asus Zenbook UX32VD GPU Fan Replacement: adım 5, 3 resimden 1. Asus Zenbook UX32VD GPU Fan Replacement: adım 5, 3 resimden 2. Asus Zenbook UX32VD GPU Fan Replacement: adım 5, 3 resimden 3.
    • Unplug the bundled cable connector.
    • Move the fan as shown in the first picture to better access the connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD GPU Fan Replacement: adım 6, 1 resimden 1.
    • Remove the fan completely.
Sonuç
Miguel Angel Felix
113 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 2,217
