Giriş
Use this guide to replace noisy or malfunctioning GPU fan in the Asus Zenbook UX32VD.
Neye ihtiyacın var
Bu adımda kullanılan alet:T5 Torx Screwdriver$9.99
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Bu adımda kullanılan alet:Spudger$2.99
Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
Remove the metallic ribbon cable from the connector .
Bu adımda kullanılan alet:Phillips #0 Screwdriver$5.49
Remove the 3 (4mm) fan screws with a Phillips #0 Screwdriver
