Ana içeriğe geç
Asus Zenbook UX32VD Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: adım 1, 3 resimden 1. Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: adım 1, 3 resimden 2. Asus Zenbook UX32VD Hard Drive Replacement, Bottom Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    T5 Torx Screwdriver
    $9.99
    Satın Al
  2. Asus Zenbook UX32VD Hard Drive Replacement: adım 2, 3 resimden 1. Asus Zenbook UX32VD Hard Drive Replacement: adım 2, 3 resimden 2. Asus Zenbook UX32VD Hard Drive Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD Hard Drive Replacement, Battery: adım 3, 2 resimden 1. Asus Zenbook UX32VD Hard Drive Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
  4. Asus Zenbook UX32VD Hard Drive Replacement: adım 4, 2 resimden 1. Asus Zenbook UX32VD Hard Drive Replacement: adım 4, 2 resimden 2.
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
  5. Asus Zenbook UX32VD Hard Drive Replacement: adım 5, 3 resimden 1. Asus Zenbook UX32VD Hard Drive Replacement: adım 5, 3 resimden 2. Asus Zenbook UX32VD Hard Drive Replacement: adım 5, 3 resimden 3.
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove the battery completely.
  7. Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 1. Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 2. Asus Zenbook UX32VD Hard Drive Replacement, Hard Drive: adım 7, 3 resimden 3.
    Phillips #0 Screwdriver
    $5.49
    Satın Al
  8. Asus Zenbook UX32VD Hard Drive Replacement: adım 8, 3 resimden 1. Asus Zenbook UX32VD Hard Drive Replacement: adım 8, 3 resimden 2. Asus Zenbook UX32VD Hard Drive Replacement: adım 8, 3 resimden 3.
    • Lift the hard drive slightly and gently pull the hard drive from the socket.
    • Do not lift the hard drive too high. Doing so could damage the hard drive or other internal components of the laptop.
    • Remove the hard drive completely.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Michael Remmel
718 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G2
4 Üyeler
6 adet Kılavuz yazıldı
4 Yorum
Installed a new WD Blue 3D NAND 500GB PC SSD - SATA III 6 Gb/s 2.5"/7mm Solid State Drive into my UX32VD using this guide. It works like charm! Thanks for the guide
Le Zap - Yanıt
Excellent! Precise and concise to the point!Thank you!
Android Phone - Yanıt
Exzellent Guide, Thank you so much!
sina - Yanıt
can someone confirm to me that samsung evo 860 will work or not for this asus please
Karim Othman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 10,863
