Ana içeriğe geç
Asus Zenbook UX32VD RAM Replacement
Neye ihtiyacın var
  1. Asus Zenbook UX32VD RAM Replacement, Bottom Panel: adım 1, 3 resimden 1. Asus Zenbook UX32VD RAM Replacement, Bottom Panel: adım 1, 3 resimden 2. Asus Zenbook UX32VD RAM Replacement, Bottom Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    T5 Torx Screwdriver
    $9.99
  2. Asus Zenbook UX32VD RAM Replacement: adım 2, 3 resimden 1. Asus Zenbook UX32VD RAM Replacement: adım 2, 3 resimden 2. Asus Zenbook UX32VD RAM Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD RAM Replacement, RAM: adım 3, 3 resimden 1. Asus Zenbook UX32VD RAM Replacement, RAM: adım 3, 3 resimden 2. Asus Zenbook UX32VD RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Push away the RAM retaining arms from the RAM chip.
    • The RAM chip will spring up once the retaining arms are pushed away from the chip.
    • Remove the RAM chip completely.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Paola
270 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G2
4 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Replaced the 4 GB RAM module in my UX32VD with an 8 GB Timetec Hynix IC DDR3 1600MHz PC3-12800 Non ECC Unbuffered 1.35V CL11 2Rx8 Dual Rank 204 Pin SODIMM Laptop Notebook Computer Memory Ram Module using this guide. It worked like a charm. Thank you for posting the guide!
Le Zap - Yanıt
Worked like a charm on a UX32VD. Installed a "Kingston SO-DDR3L-RAM ValueRAM 1600 MHz 1x 8 GB" in 3min
HUGE DIFFERENCE
Thank you very much!
PS. There was a foil wrapper around the old RAM that I removed and put around the new RAM. Heat dissipation I imagine
Valentin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 37
Her zaman: 4,749
