Ana içeriğe geç
Asus Zenfone 3 Max Motherboard Replacement
Neye ihtiyacın var
  1. Asus Zenfone 3 Max Motherboard Replacement, SIM card: adım 1, 1 resimden 1.
    • Locate the SIM card slot on the upper left side of your Asus Zenfone Max 3.
  2. Asus Zenfone 3 Max Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the iFixit 150mm Flex Extension with the Hex 0.7 bit or the SIM card eject tool.
    • Stick the tool into the hole on the SIM card slot and open the slot with it.
  3. Asus Zenfone 3 Max Motherboard Replacement: adım 3, 1 resimden 1.
    • Pull out the old SIM card all the way so it is no longer in the phone.
  4. Asus Zenfone 3 Max Motherboard Replacement, Back cover: adım 4, 2 resimden 1. Asus Zenfone 3 Max Motherboard Replacement, Back cover: adım 4, 2 resimden 2.
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  5. Asus Zenfone 3 Max Motherboard Replacement: adım 5, 1 resimden 1.
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  6. Asus Zenfone 3 Max Motherboard Replacement, Battery: adım 6, 3 resimden 1. Asus Zenfone 3 Max Motherboard Replacement, Battery: adım 6, 3 resimden 2. Asus Zenfone 3 Max Motherboard Replacement, Battery: adım 6, 3 resimden 3.
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  7. Asus Zenfone 3 Max Motherboard Replacement: adım 7, 3 resimden 1. Asus Zenfone 3 Max Motherboard Replacement: adım 7, 3 resimden 2. Asus Zenfone 3 Max Motherboard Replacement: adım 7, 3 resimden 3.
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
  8. Asus Zenfone 3 Max Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Asus Zenfone 3 Max Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Remove the two 2.5mm Phillips #0 screws located in the upper corners of the device indicated with red circles.
    • After both screws have been removed, detach the white plastic internal panel completely from the device.
  9. Asus Zenfone 3 Max Motherboard Replacement: adım 9, 3 resimden 1. Asus Zenfone 3 Max Motherboard Replacement: adım 9, 3 resimden 2. Asus Zenfone 3 Max Motherboard Replacement: adım 9, 3 resimden 3.
    • Next, remove the four 2.5mm Phillips #0 screws surrounding the motherboard component.
    • Following the removal of all four screws, carefully detach the two device cables at the bottom of the motherboard component using the nylon spudger.
    • Next, disconnect the remaining component cable using the same technique described in the previous step.
    • Metal spudgers should not be used on internal components, they are not ESD safe.
  10. Asus Zenfone 3 Max Motherboard Replacement: adım 10, 2 resimden 1. Asus Zenfone 3 Max Motherboard Replacement: adım 10, 2 resimden 2.
    • Carefully grip the motherboard and gently lift and remove it from the internal device casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lauren Compton
372 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 1,252
