Ana içeriğe geç
Asus Zenfone 3 Zoom Battery Replacement
Neye ihtiyacın var
  1. Asus Zenfone 3 Zoom Battery Replacement, Battery: adım 1, 2 resimden 1. Asus Zenfone 3 Zoom Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. Asus Zenfone 3 Zoom Battery Replacement: adım 2, 1 resimden 1.
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. Asus Zenfone 3 Zoom Battery Replacement: adım 3, 2 resimden 1. Asus Zenfone 3 Zoom Battery Replacement: adım 3, 2 resimden 2.
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. Asus Zenfone 3 Zoom Battery Replacement: adım 4, 1 resimden 1.
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. Asus Zenfone 3 Zoom Battery Replacement: adım 5, 1 resimden 1.
    • Peel back the silver tape.
  6. Asus Zenfone 3 Zoom Battery Replacement: adım 6, 1 resimden 1.
    • Disconnect the battery connections.
  7. Asus Zenfone 3 Zoom Battery Replacement: adım 7, 1 resimden 1.
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 3,758
