Ana içeriğe geç
Asus Zenfone 4 Max Camera Replacement
Neye ihtiyacın var
  1. Asus Zenfone 4 Max Camera Replacement, Camera: adım 1, 1 resimden 1.
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: adım 2, 1 resimden 1.
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: adım 3, 2 resimden 1. Asus Zenfone 4 Max Camera Replacement: adım 3, 2 resimden 2.
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: adım 4, 3 resimden 1. Asus Zenfone 4 Max Camera Replacement: adım 4, 3 resimden 2. Asus Zenfone 4 Max Camera Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
Sonuç
Maegan West
839 İtibar
4 adet Kılavuz yazıldı
Ekip
2 Yorum
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - Yanıt
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,950
