Ana içeriğe geç
Asus Zenfone 4 Max Charging Port Replacement
Neye ihtiyacın var
  1. Asus Zenfone 4 Max Charging Port Replacement, Battery: adım 1, 2 resimden 1. Asus Zenfone 4 Max Charging Port Replacement, Battery: adım 1, 2 resimden 2.
    • Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
  2. Asus Zenfone 4 Max Charging Port Replacement: adım 2, 1 resimden 1.
    • Gently wedge the opening tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  3. Asus Zenfone 4 Max Charging Port Replacement: adım 3, 3 resimden 1. Asus Zenfone 4 Max Charging Port Replacement: adım 3, 3 resimden 2. Asus Zenfone 4 Max Charging Port Replacement: adım 3, 3 resimden 3.
    • Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
  4. Asus Zenfone 4 Max Charging Port Replacement: adım 4, 1 resimden 1.
    • Remove the bottom panel.
  5. Asus Zenfone 4 Max Charging Port Replacement: adım 5, 2 resimden 1. Asus Zenfone 4 Max Charging Port Replacement: adım 5, 2 resimden 2.
    • Wedge an opening tool between the battery and phone.
    • Gently pry the battery out of the device.
    • You can move the opening on either side of the battery as well as the bottom to aid in removal.
  6. Asus Zenfone 4 Max Charging Port Replacement: adım 6, 1 resimden 1.
    • Remove the battery and replace it with the new battery.
  7. Asus Zenfone 4 Max Charging Port Replacement, Charging Port: adım 7, 3 resimden 1. Asus Zenfone 4 Max Charging Port Replacement, Charging Port: adım 7, 3 resimden 2. Asus Zenfone 4 Max Charging Port Replacement, Charging Port: adım 7, 3 resimden 3.
    • Once the battery has been removed, gently wedge the metal spudger beneath the green panel.
    • Lift the panel along with the charging port out the device and replace with the new charging port.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Maegan West
839 İtibar
4 adet Kılavuz yazıldı
Ekip
2 Yorum
repair microfone asus zenfone 4 selfie pro please
John Wesley - Yanıt
I have managed to replace the charging port but now it shows Charging Port Temperatures Abnormalities Reminder which is loud and annoying to see every time. I also see that one of my sensors in the cpu-z program (thermal sensor pa_therm0) hitting a constant 75-84 degree centigrade and another sensor (chg_temp) hitting 65 constantly. Any help in regards to this manner?
Max Orwell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 3,211
