Ana içeriğe geç
Atari 2600 Jr. Rev. A Disassembly
Neye ihtiyacın var
  1. Atari 2600 Jr. Rev. A Disassembly, Remove the base: adım 1, 1 resimden 1.
    • Remove 5 Phillips screws from base.
  2. Atari 2600 Jr. Rev. A Disassembly, Detach the Case: adım 2, 3 resimden 1. Atari 2600 Jr. Rev. A Disassembly, Detach the Case: adım 2, 3 resimden 2. Atari 2600 Jr. Rev. A Disassembly, Detach the Case: adım 2, 3 resimden 3.
    • Use a metal or heavy duty spudger to unhook the 3 plastic clips holding the front of the case together.
    • Be careful not to break the plastic clips
    • While unhooking the center hook use another spudger to run along the top and bottom casing. This helps to get the clip lose.
    • Be careful not to pull the case apart quickly, there is a ribbon that is attached to the top and bottom.
  3. Atari 2600 Jr. Rev. A Disassembly, Detach the Ribbon: adım 3, 1 resimden 1.
    • Detach the ribbon from the circuit board by gently pulling ribbon out from clip.
  4. Atari 2600 Jr. Rev. A Disassembly, Remove Circuit Board from Base: adım 4, 2 resimden 1. Atari 2600 Jr. Rev. A Disassembly, Remove Circuit Board from Base: adım 4, 2 resimden 2.
    • There are 2 clips holding the circuit board in place.
    • Using a metal or heavy duty spudger release the clip on the left side.
    • Remove the circuit board.
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
Aislinn
294 İtibar
1 Kılavuz yazıldı
Bir Yorum
Great process for dis-assembly. Now all I need is a replacement reed switch as mine is broken. Being in Australia it is very hard to find one locally. many Thanks.
Singoau - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 51
Her zaman: 4,114
