Ana içeriğe geç
Atari 5200 Controller Side Buttons Replacement
Neye ihtiyacın var
  1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: adım 1, 3 resimden 1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: adım 1, 3 resimden 2. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: adım 1, 3 resimden 3.
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    FixBot'a Sor
    Yorum Ekle
  2. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: adım 2, 2 resimden 1. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: adım 2, 2 resimden 2.
    • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
    • Realign the buttons over the sensors/clean the sensor contacts.
    • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
    • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
    FixBot'a Sor
    Yorum Ekle
  3. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: adım 3, 2 resimden 1. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: adım 3, 2 resimden 2.
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
    FixBot'a Sor
    Yorum Ekle
  4. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: adım 4, 2 resimden 1. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: adım 4, 2 resimden 2.
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
    FixBot'a Sor
    Yorum Ekle
  5. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: adım 5, 3 resimden 1. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: adım 5, 3 resimden 2. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: adım 5, 3 resimden 3.
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alan Abelson
233 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G1
5 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 1,449
