Neye ihtiyacın var
Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
Realign the buttons over the sensors/clean the sensor contacts.
Use a spudger to remove the top frame.
Take off the plate.
Remove the rubber buttons.
Pull the circuit strip through the new space.
Realign the top and bottom of the controller.
Return the buttons to the top of the controller.
Snap the frame back into place.
Screw the screws.
Bir başkası bu kılavuzu tamamladı.
