Ana içeriğe geç
Atari 5200 Motherboard Cleaning
Neye ihtiyacın var
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: adım 1, 1 resimden 1.
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Atari 5200 Motherboard Cleaning: adım 2, 1 resimden 1.
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. Atari 5200 Motherboard Cleaning, Access: Granted: adım 3, 1 resimden 1.
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zach Petryszyn
21 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G1
5 Üyeler
17 adet Kılavuz yazıldı
Bir Yorum
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 2,615
