Ana içeriğe geç
Atari 5200 Entertainment System Power Button Replacement
Neye ihtiyacın var
  1. Atari 5200 Entertainment System Power Button Replacement, Entertainment System Power Button: adım 1, 1 resimden 1.
    • Gently flip the Atari Entertainment System over. You'll see 7 screws holding the system together. Use a philips head screw driver to remove all seven screws.
    • Pictured above is the Atari 5200 upside down. The orange edited circles over all 7 screws.
    FixBot'a Sor
    Yorum Ekle
  2. Atari 5200 Entertainment System Power Button Replacement: adım 2, 1 resimden 1.
    • Gently flip the Atari Entertainment System over to the front side. Remove the top.
    FixBot'a Sor
    Yorum Ekle
  3. Atari 5200 Entertainment System Power Button Replacement: adım 3, 3 resimden 1. Atari 5200 Entertainment System Power Button Replacement: adım 3, 3 resimden 2. Atari 5200 Entertainment System Power Button Replacement: adım 3, 3 resimden 3.
    • There are orange objects on the side of the system's top, pinch them.
    • If the triangles cannot be gripped, push the power button on the opposite side. This will lift the triangle to give access to easier grip.
    FixBot'a Sor
    Yorum Ekle
  4. Atari 5200 Entertainment System Power Button Replacement: adım 4, 3 resimden 1. Atari 5200 Entertainment System Power Button Replacement: adım 4, 3 resimden 2. Atari 5200 Entertainment System Power Button Replacement: adım 4, 3 resimden 3.
    • The Power button can now be removed/clean/replaced.
    • Be sure to keep an eye on the spring.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alan Abelson
233 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G1
5 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 44
Her zaman: 2,084
