Ana içeriğe geç
Atari 5200 Game Cartridge Disassembly
Neye ihtiyacın var
  1. Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: adım 1, 3 resimden 1. Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: adım 1, 3 resimden 2. Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: adım 1, 3 resimden 3.
    • Flip the cartridge over.
    • Unscrew the single screw on the back.
    • Carefully pry apart the casing. There are six (6) tabs that need to be released, three (3) each side. If you're not careful they will break. (experience has taught me)
    • Set aside any case parts after dissassembly.
    FixBot'a Sor
    Yorum Ekle
  2. Atari 5200 Game Cartridge Disassembly, Cleaning the Parts: adım 2, 1 resimden 1.
    • Unscrew the board casing, and remove it.
    • Use a compressed air can to blow off any excess dust off the board.
    • Use an alcohol-dabbed cloth to wipe down the gold-plated contacts of the board.
    FixBot'a Sor
    Yorum Ekle
  3. Atari 5200 Game Cartridge Disassembly, Reassembly: adım 3, 3 resimden 1. Atari 5200 Game Cartridge Disassembly, Reassembly: adım 3, 3 resimden 2. Atari 5200 Game Cartridge Disassembly, Reassembly: adım 3, 3 resimden 3.
    • Place the two contact protectors together.
    • Place the spring on the knob in the cartridge.
    FixBot'a Sor
    Yorum Ekle
  4. Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: adım 4, 3 resimden 1. Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: adım 4, 3 resimden 2. Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: adım 4, 3 resimden 3.
    • Thread the spring into the connected plates.
    • Push the plates into the cartridge against the pressure of the spring.
    FixBot'a Sor
    Yorum Ekle
  5. Atari 5200 Game Cartridge Disassembly, Finishing up: adım 5, 3 resimden 1. Atari 5200 Game Cartridge Disassembly, Finishing up: adım 5, 3 resimden 2. Atari 5200 Game Cartridge Disassembly, Finishing up: adım 5, 3 resimden 3.
    • Place the chip in the case.
    • It should "pop" into place.
    • Screw the other side of the case on.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Be sure to test the game, and if freezing still occurs, check the contacts once again.
3 farklı kişi bu kılavuzu tamamladı.
Zach Petryszyn
21 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 üyesi
USFT-STAGGERS-F14S13G1
5 Üyeler
17 adet Kılavuz yazıldı
2Kılavuz Yorumları
I’m curious to see the Atari 2600 cartridge inside but I can’t get my hands on one.
The official meme centre. - Yanıt Paylaş
it's not a 2600 cart. the systems have similarities, but they are not pin compatible, nor are they software compatible. the 5200 is its own thing.
Gorilla Sapiens - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 57
Her zaman: 4,040
