Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Atari Flashback 2 Console Power Button Replacement
Neye ihtiyacın var
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: adım 1, 3 resimden 1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: adım 1, 3 resimden 2. Atari Flashback 2 Console Power Button Replacement, Console Power Button: adım 1, 3 resimden 3.
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Console Power Button Replacement: adım 2, 3 resimden 1. Atari Flashback 2 Console Power Button Replacement: adım 2, 3 resimden 2. Atari Flashback 2 Console Power Button Replacement: adım 2, 3 resimden 3.
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
Sonuç
Faith Julian
205 İtibar
2 adet Kılavuz yazıldı
Ekip
Washington State, Team S1-G2, Hope Fall 2018 Washington State, Team S1-G2, Hope Fall 2018 üyesi
WSU-HOPE-F18S1G2
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 773
