Ana içeriğe geç
Atari Flashback 2 Difficulty Button Replacement
Neye ihtiyacın var
  1. Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: adım 1, 3 resimden 1. Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: adım 1, 3 resimden 2. Atari Flashback 2 Difficulty Button Replacement, Difficulty Button: adım 1, 3 resimden 3.
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
    FixBot'a Sor
    Yorum Ekle
  2. Atari Flashback 2 Difficulty Button Replacement: adım 2, 2 resimden 1. Atari Flashback 2 Difficulty Button Replacement: adım 2, 2 resimden 2.
    • Unscrew the two 10.0 mm Phillips #1 screws, and gently pull back the green circuit board.
    • Remove gently. The circuit board is connected by wire to the board. Removing the cable from the console case may allow more slack.
    • The button springs may be under compression.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Ramadan
135 İtibar
1 Kılavuz yazıldı
Ekip
Washington State, Team S1-G2, Hope Fall 2018 Washington State, Team S1-G2, Hope Fall 2018 üyesi
WSU-HOPE-F18S1G2
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 54
Her zaman: 707
