Ana içeriğe geç
Atari Flashback 2 Reset and Select Button Replacement
Neye ihtiyacın var
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: adım 1, 3 resimden 1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: adım 1, 3 resimden 2. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: adım 1, 3 resimden 3.
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
    FixBot'a Sor
    Yorum Ekle
  2. Atari Flashback 2 Reset and Select Button Replacement: adım 2, 3 resimden 1. Atari Flashback 2 Reset and Select Button Replacement: adım 2, 3 resimden 2. Atari Flashback 2 Reset and Select Button Replacement: adım 2, 3 resimden 3.
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ekip
Washington State, Team S1-G2, Hope Fall 2018 Washington State, Team S1-G2, Hope Fall 2018 üyesi
WSU-HOPE-F18S1G2
4 Üyeler
11 adet Kılavuz yazıldı
2Kılavuz Yorumları
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Yanıt Paylaş
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 70
Her zaman: 1,322
