Ana içeriğe geç
Atari Flashback 2 Reset and Select Button Replacement
Neye ihtiyacın var
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: adım 1, 3 resimden 1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: adım 1, 3 resimden 2. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: adım 1, 3 resimden 3.
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: adım 2, 3 resimden 1. Atari Flashback 2 Reset and Select Button Replacement: adım 2, 3 resimden 2. Atari Flashback 2 Reset and Select Button Replacement: adım 2, 3 resimden 3.
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
Sonuç
Gabriel Robinson
85 İtibar
1 Kılavuz yazıldı
Ekip
Washington State, Team S1-G2, Hope Fall 2018 Washington State, Team S1-G2, Hope Fall 2018 üyesi
WSU-HOPE-F18S1G2
4 Üyeler
11 adet Kılavuz yazıldı
2 Yorum
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Yanıt
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 743
