Ana içeriğe geç
Atmega328P Microcontroller Replacement for Arduino Board
Neye ihtiyacın var
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: adım 1, 1 resimden 1.
    • Place the Arduino UNO R3 board on a flat clean surface.
  2. Atmega328P Microcontroller Replacement for Arduino Board: adım 2, 2 resimden 1. Atmega328P Microcontroller Replacement for Arduino Board: adım 2, 2 resimden 2.
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
  3. Atmega328P Microcontroller Replacement for Arduino Board: adım 3, 2 resimden 1. Atmega328P Microcontroller Replacement for Arduino Board: adım 3, 2 resimden 2.
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
  4. Atmega328P Microcontroller Replacement for Arduino Board: adım 4, 3 resimden 1. Atmega328P Microcontroller Replacement for Arduino Board: adım 4, 3 resimden 2. Atmega328P Microcontroller Replacement for Arduino Board: adım 4, 3 resimden 3.
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
  5. Atmega328P Microcontroller Replacement for Arduino Board: adım 5, 1 resimden 1.
    • Remove replacement microcontroller out of packaging.
  6. Atmega328P Microcontroller Replacement for Arduino Board: adım 6, 1 resimden 1.
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
  7. Atmega328P Microcontroller Replacement for Arduino Board: adım 7, 2 resimden 1. Atmega328P Microcontroller Replacement for Arduino Board: adım 7, 2 resimden 2.
    • Gently press the microcontroller into the dip socket
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Youssef Qteshat
193 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 5-5, Morris Winter 2023 UC Davis, Team 5-5, Morris Winter 2023 üyesi
UCD-MORRIS-W23S5G5
2 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 404
