Ana içeriğe geç
Atmega328P Microcontroller Replacement for Arduino Board
Neye ihtiyacın var
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: adım 1, 1 resimden 1.
    • Place the Arduino UNO R3 board on a flat clean surface.
    FixBot'a Sor
    Yorum Ekle
  2. Atmega328P Microcontroller Replacement for Arduino Board: adım 2, 2 resimden 1. Atmega328P Microcontroller Replacement for Arduino Board: adım 2, 2 resimden 2.
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
    FixBot'a Sor
    Yorum Ekle
  3. Atmega328P Microcontroller Replacement for Arduino Board: adım 3, 2 resimden 1. Atmega328P Microcontroller Replacement for Arduino Board: adım 3, 2 resimden 2.
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
    FixBot'a Sor
    Yorum Ekle
  4. Atmega328P Microcontroller Replacement for Arduino Board: adım 4, 3 resimden 1. Atmega328P Microcontroller Replacement for Arduino Board: adım 4, 3 resimden 2. Atmega328P Microcontroller Replacement for Arduino Board: adım 4, 3 resimden 3.
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
    FixBot'a Sor
    Yorum Ekle
  5. Atmega328P Microcontroller Replacement for Arduino Board: adım 5, 1 resimden 1.
    • Remove replacement microcontroller out of packaging.
    FixBot'a Sor
    Yorum Ekle
  6. Atmega328P Microcontroller Replacement for Arduino Board: adım 6, 1 resimden 1.
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
    FixBot'a Sor
    Yorum Ekle
  7. Atmega328P Microcontroller Replacement for Arduino Board: adım 7, 2 resimden 1. Atmega328P Microcontroller Replacement for Arduino Board: adım 7, 2 resimden 2.
    • Gently press the microcontroller into the dip socket
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Youssef Qteshat
217 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 5-5, Morris Winter 2023 UC Davis, Team 5-5, Morris Winter 2023 üyesi
UCD-MORRIS-W23S5G5
2 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 61
Her zaman: 1,408
