Ana içeriğe geç
Audio Technica ATH-AD500 Driver Replacement
Neye ihtiyacın var
  1. Audio Technica ATH-AD500 Driver Replacement, Speaker Assembly: adım 1, 1 resimden 1.
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Driver Replacement: adım 2, 1 resimden 1.
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Driver Replacement: adım 3, 1 resimden 1.
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Driver Replacement, Driver: adım 4, 1 resimden 1.
    • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  5. Audio Technica ATH-AD500 Driver Replacement: adım 5, 1 resimden 1.
    • Pull the driver out of its bracket.
  6. Audio Technica ATH-AD500 Driver Replacement: adım 6, 2 resimden 1. Audio Technica ATH-AD500 Driver Replacement: adım 6, 2 resimden 2.
    • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference How To Solder and Desolder Connections.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  7. Audio Technica ATH-AD500 Driver Replacement: adım 7, 2 resimden 1. Audio Technica ATH-AD500 Driver Replacement: adım 7, 2 resimden 2.
    • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
    • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nick Levy
183 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G19
6 Üyeler
17 adet Kılavuz yazıldı
2Kılavuz Yorumları
where can i buy a replacement driver?
acidxgangster - Yanıt Paylaş
You can order parts directly from PARTS@ATUS.COM
Nick Levy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 69
Her zaman: 11,658
