Giriş
This repair guide will help you with the following:
  • Install the left headphone cable
  • Fix sound coming from the left headphone
  1. Remove the ear pads by peeling them away from the grill.
    • Remove the ear pads by peeling them away from the grill.
  2. Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove the speaker from the grill by pulling it out.
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  5. Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections. The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again. The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  6. Untie the knot in the thick main cable. Remove the main cable from the headphones by pulling it out.
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
  7. Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference How To Solder and Desolder Connections. The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again. The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Melanie Reis
121 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G19
6 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Thank you so much! your guide helped me repair my AD900x!
Anwar X - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 Gün: 19
Son 30 Gün: 86
Her zaman: 5,137
