Ana içeriğe geç
Audio-Technica AT-LP120-USB Outer Shell Replacement
Neye ihtiyacın var
  1. Audio-Technica AT-LP120-USB Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 1. Audio-Technica AT-LP120-USB Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 2. Audio-Technica AT-LP120-USB Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 3.
    • Remove the inner steel plate that spins on the turntable.
    • Carefully lift up the plate.
    • Place it near your device out of the way.
  2. Audio-Technica AT-LP120-USB Outer Shell Replacement: adım 2, 1 resimden 1.
    • Remove the power cord in the back of the device.
  3. Audio-Technica AT-LP120-USB Outer Shell Replacement: adım 3, 1 resimden 1.
    • Ensure that the Tone Arm clamp is in place.
  4. Audio-Technica AT-LP120-USB Outer Shell Replacement: adım 4, 2 resimden 1. Audio-Technica AT-LP120-USB Outer Shell Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the eight 2 mm screws holding the back casing into place.
    • Carefully remove the back casing from the device to expose the interior.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David
253 İtibar
2 adet Kılavuz yazıldı
Ekip
Cuesta, Team 20-3, Krynen Fall 2024 Cuesta, Team 20-3, Krynen Fall 2024 üyesi
CUESTA-KRYNEN-F24S20G3
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 40
