Ana içeriğe geç
Audiovox CDM-8900 Keypad Replacement
Neye ihtiyacın var
  1. Audiovox CDM-8900 Keypad Replacement, Battery: adım 1, 2 resimden 1. Audiovox CDM-8900 Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
  2. Audiovox CDM-8900 Keypad Replacement, Antenna: adım 2, 3 resimden 1. Audiovox CDM-8900 Keypad Replacement, Antenna: adım 2, 3 resimden 2. Audiovox CDM-8900 Keypad Replacement, Antenna: adım 2, 3 resimden 3.
    • Grasp the antenna at its base and twist to unscrew.
    • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
  3. Audiovox CDM-8900 Keypad Replacement, Motherboard: adım 3, 3 resimden 1. Audiovox CDM-8900 Keypad Replacement, Motherboard: adım 3, 3 resimden 2. Audiovox CDM-8900 Keypad Replacement, Motherboard: adım 3, 3 resimden 3.
    • Remove the small rubber insert from the top of the phone to access the top screw.
    • Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
    • If screws do not slide out after unscrewing, gently flip and tap the phone in your hand until the screws come loose.
  4. Audiovox CDM-8900 Keypad Replacement: adım 4, 3 resimden 1. Audiovox CDM-8900 Keypad Replacement: adım 4, 3 resimden 2. Audiovox CDM-8900 Keypad Replacement: adım 4, 3 resimden 3.
    • Wedge the phone plate toward you, using the leverage from an opening tool.
    • The volume control button on the left side of the phone will loosen. Make sure to carefully reinsert it during reassembly.
    • Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
  5. Audiovox CDM-8900 Keypad Replacement: adım 5, 3 resimden 1. Audiovox CDM-8900 Keypad Replacement: adım 5, 3 resimden 2. Audiovox CDM-8900 Keypad Replacement: adım 5, 3 resimden 3.
    • To release the motherboard, push the large "OK" button located on the other side of the phone.
    • Before reassembly, make sure the keypad is lined up with the motherboard. Be sure the camera lens is properly aligned at the top of the motherboard and the volume controls are in place.
  6. Audiovox CDM-8900 Keypad Replacement, Keypad: adım 6, 1 resimden 1.
    • Peel away keypad from faceplate.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Aaron Shaw
159 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 28-31, Regan Spring 2010 Cal Poly, Team 28-31, Regan Spring 2010 üyesi
CPSU-REGAN-S10S28G31
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,866
