Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The antenna allows the transmittal of signals necessary for the Audiovox CDM-8910 to function. Replacing a malfunctioning antenna is a simple process that could improve phone performance.
  1. Locate the antenna (shown in red box) at the top of the phone when closed.
    • Locate the antenna (shown in red box) at the top of the phone when closed.
  2. Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise.  Once loose, remove the antenna by pulling it from its insert hole.
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Jafarey
11 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G24
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 820
