Ana içeriğe geç
Audiovox CDM-8910 Keyboard Replacement
Neye ihtiyacın var
  1. Audiovox CDM-8910 Keyboard Replacement, Antenna: adım 1, 1 resimden 1.
    • Locate the antenna (shown in red box) at the top of the phone when closed.
    FixBot'a Sor
    Yorum Ekle
  2. Audiovox CDM-8910 Keyboard Replacement: adım 2, 1 resimden 1.
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
    FixBot'a Sor
    Yorum Ekle
  3. Audiovox CDM-8910 Keyboard Replacement, Battery: adım 3, 1 resimden 1.
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
    FixBot'a Sor
    Yorum Ekle
  4. Audiovox CDM-8910 Keyboard Replacement: adım 4, 1 resimden 1.
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Audiovox CDM-8910 Keyboard Replacement: adım 5, 1 resimden 1.
    • The back of the phone will look like this when the battery is correctly removed.
    FixBot'a Sor
    Yorum Ekle
  6. Audiovox CDM-8910 Keyboard Replacement, Rear Case: adım 6, 1 resimden 1.
    • Peel the rubber indicated toward the top of the phone
    FixBot'a Sor
    Yorum Ekle
  7. Audiovox CDM-8910 Keyboard Replacement: adım 7, 1 resimden 1.
    • Remove the screw that sits underneath the rubber covering.
    FixBot'a Sor
    Yorum Ekle
  8. Audiovox CDM-8910 Keyboard Replacement: adım 8, 1 resimden 1.
    • Remove the five (5) total screws using a Philips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Audiovox CDM-8910 Keyboard Replacement: adım 9, 1 resimden 1.
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
    FixBot'a Sor
    Yorum Ekle
  10. Audiovox CDM-8910 Keyboard Replacement: adım 10, 1 resimden 1.
    • The back case should now be completely removed and the motherboard will be visible.
    FixBot'a Sor
    Yorum Ekle
  11. Audiovox CDM-8910 Keyboard Replacement, Motherboard: adım 11, 3 resimden 1. Audiovox CDM-8910 Keyboard Replacement, Motherboard: adım 11, 3 resimden 2. Audiovox CDM-8910 Keyboard Replacement, Motherboard: adım 11, 3 resimden 3.
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
    FixBot'a Sor
    Yorum Ekle
  12. Audiovox CDM-8910 Keyboard Replacement: adım 12, 1 resimden 1.
    • Using a spudger, lift the motherboard out of the phone case as pictured.
    FixBot'a Sor
    Yorum Ekle
  13. Audiovox CDM-8910 Keyboard Replacement: adım 13, 1 resimden 1.
    • The motherboard should now be completely removed from the phone.
    FixBot'a Sor
    Yorum Ekle
  14. Audiovox CDM-8910 Keyboard Replacement, Keyboard: adım 14, 1 resimden 1.
    • Once the motherboard has been removed, peel the keyboard as pictured.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Carlos Guerrero
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G24
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 1,781
