Ana içeriğe geç
Audiovox CDM-8910 LCD Screen Replacement
Neye ihtiyacın var
  1. Audiovox CDM-8910 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
  2. Audiovox CDM-8910 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
  3. Audiovox CDM-8910 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
  4. Audiovox CDM-8910 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Use a spudger to lift away and remove the metallic frame (in blue).
    • Use the spudger to lift away the two electrical contacts (in red).
    • Use the spudger to lift away the speaker (in yellow).
  5. Audiovox CDM-8910 LCD Screen Replacement: adım 5, 1 resimden 1.
    • This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
  6. Audiovox CDM-8910 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Use a spudger to lift away the LCD screen.
  7. Audiovox CDM-8910 LCD Screen Replacement: adım 7, 1 resimden 1.
    • LCD screen successfully removed!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Jafarey
11 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G24
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,921
