Ana içeriğe geç
Audiovox CDM-8910 Motherboard Replacement
Neye ihtiyacın var
  1. Audiovox CDM-8910 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
  2. Audiovox CDM-8910 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
  3. Audiovox CDM-8910 Motherboard Replacement: adım 3, 1 resimden 1.
    • The back of the phone will look like this when the battery is correctly removed.
  4. Audiovox CDM-8910 Motherboard Replacement, Rear Case: adım 4, 1 resimden 1.
    • Peel the rubber indicated toward the top of the phone
  5. Audiovox CDM-8910 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the screw that sits underneath the rubber covering.
  6. Audiovox CDM-8910 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the five (5) total screws using a Philips head screwdriver.
  7. Audiovox CDM-8910 Motherboard Replacement: adım 7, 1 resimden 1.
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
  8. Audiovox CDM-8910 Motherboard Replacement: adım 8, 1 resimden 1.
    • The back case should now be completely removed and the motherboard will be visible.
  9. Audiovox CDM-8910 Motherboard Replacement, Motherboard: adım 9, 3 resimden 1. Audiovox CDM-8910 Motherboard Replacement, Motherboard: adım 9, 3 resimden 2. Audiovox CDM-8910 Motherboard Replacement, Motherboard: adım 9, 3 resimden 3.
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
  10. Audiovox CDM-8910 Motherboard Replacement: adım 10, 1 resimden 1.
    • Using a spudger, lift the motherboard out of the phone case as pictured.
  11. Audiovox CDM-8910 Motherboard Replacement: adım 11, 1 resimden 1.
    • The motherboard should now be completely removed from the phone.
Sonuç
Sean Green
29 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G24
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Where on this phone’s motherboard is the memory card located? I’d like to try and remove mine to download the data from it.
Ernie Freeman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 2,213
