Neye ihtiyacın var
Flip your phone over so the screen is facing down.
About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
Once the battery has been removed, you will need a small Phillips 60 mm screwdriver. Remove the two 1.2mm Phillips #1 screws on the back of the phone.
Use a spudger tool to pry apart the phone. It may be a little difficult to pry open. Use the flat part of the spudger tool and go all around the phone. It will come apart.
2 farklı kişi bu kılavuzu tamamladı.
