Ana içeriğe geç
Audiovox Tri-mode CDM-9000 Keypad Replacement
Neye ihtiyacın var
  1. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: adım 1, 3 resimden 1. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: adım 1, 3 resimden 2. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: adım 1, 3 resimden 3.
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Keypad Replacement: adım 2, 3 resimden 1. Audiovox Tri-mode CDM-9000 Keypad Replacement: adım 2, 3 resimden 2. Audiovox Tri-mode CDM-9000 Keypad Replacement: adım 2, 3 resimden 3.
    • Once the battery has been removed, you will need a small Phillips 60 mm screwdriver. Remove the two 1.2mm Phillips #1 screws on the back of the phone.
    • Use a spudger tool to pry apart the phone. It may be a little difficult to pry open. Use the flat part of the spudger tool and go all around the phone. It will come apart.
  3. Audiovox Tri-mode CDM-9000 Keypad Replacement: adım 3, 3 resimden 1. Audiovox Tri-mode CDM-9000 Keypad Replacement: adım 3, 3 resimden 2. Audiovox Tri-mode CDM-9000 Keypad Replacement: adım 3, 3 resimden 3.
    • Once you have the phone apart simply remove the key pad and replace it with the new one.
    • Don't forget to put the screws back in. Place the battery back on the phone.
    • Push the two parts of the phone back together. You will here a loud click when the phone is back together.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Summer Sines
406 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 252
