Ana içeriğe geç
August Smart Lock Accelerometer Replacement
Neye ihtiyacın var
  1. August Smart Lock Accelerometer Replacement, Accelerometer: adım 1, 3 resimden 1. August Smart Lock Accelerometer Replacement, Accelerometer: adım 1, 3 resimden 2. August Smart Lock Accelerometer Replacement, Accelerometer: adım 1, 3 resimden 3.
    • Flip device over so the black bottom is facing you.
    • Undo latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
    FixBot'a Sor
  2. August Smart Lock Accelerometer Replacement: adım 2, 3 resimden 1. August Smart Lock Accelerometer Replacement: adım 2, 3 resimden 2. August Smart Lock Accelerometer Replacement: adım 2, 3 resimden 3.
    • Grab the gears and lift them up to remove from the device
    FixBot'a Sor
  3. August Smart Lock Accelerometer Replacement: adım 3, 3 resimden 1. August Smart Lock Accelerometer Replacement: adım 3, 3 resimden 2. August Smart Lock Accelerometer Replacement: adım 3, 3 resimden 3.
    • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
    • Disconnect the speaker plug from the motherboard
    • Disconnect the battery plugs from the motherboard.
    FixBot'a Sor
  4. August Smart Lock Accelerometer Replacement: adım 4, 1 resimden 1.
    • Once the speaker is disconnected, remove the back cover.
    • Lift up the motherboard and motor assembly out of the device.
    FixBot'a Sor
  5. August Smart Lock Accelerometer Replacement: adım 5, 2 resimden 1. August Smart Lock Accelerometer Replacement: adım 5, 2 resimden 2.
    • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
    • Lift up the black tab to remove the ribbon from the motherboard.
    FixBot'a Sor
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
William Fink
841 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G6
4 Üyeler
7Kılavuz Yorumları
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Yanıt Paylaş
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Yanıt Paylaş
Same as above…. where to locate an accelerometer??
osallabe - Yanıt Paylaş
Did anyone find out where to buy the part?
LBurd - Yanıt Paylaş
Where can I find one
Jeff Wasilewski - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 71
Her zaman: 8,756
