Ana içeriğe geç
August Smart Lock Gear Replacement
Neye ihtiyacın var
  1. August Smart Lock Gear Replacement, Gear: adım 1, 3 resimden 1. August Smart Lock Gear Replacement, Gear: adım 1, 3 resimden 2. August Smart Lock Gear Replacement, Gear: adım 1, 3 resimden 3.
    • Flip the device over so the metal plate is facing you.
    • Undo the latches on the side to remove the metal plate.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  2. August Smart Lock Gear Replacement: adım 2, 3 resimden 1. August Smart Lock Gear Replacement: adım 2, 3 resimden 2. August Smart Lock Gear Replacement: adım 2, 3 resimden 3.
    • Lift the cover off the device and set to the side.
    • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
    • Remove the gears as shown.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
William Fink
841 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G6
4 Üyeler
8Kılavuz Yorumları
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - Yanıt Paylaş
Any tips on where to get replacement gears?
Byron H - Yanıt Paylaş
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - Yanıt Paylaş
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante - Yanıt Paylaş
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 78
Her zaman: 14,023
