Ana içeriğe geç
August Smart Lock Speaker Replacement
Neye ihtiyacın var
  1. August Smart Lock Speaker Replacement, Speaker: adım 1, 3 resimden 1. August Smart Lock Speaker Replacement, Speaker: adım 1, 3 resimden 2. August Smart Lock Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Flip the device so the back cover is facing you.
    • Undo the latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  2. August Smart Lock Speaker Replacement: adım 2, 3 resimden 1. August Smart Lock Speaker Replacement: adım 2, 3 resimden 2. August Smart Lock Speaker Replacement: adım 2, 3 resimden 3.
    • Use the metal spudger to pry the plug off of the motherboard.
    • The plug can be dislodged when prying it from the side.
    FixBot'a Sor
    Yorum Ekle
  3. August Smart Lock Speaker Replacement: adım 3, 3 resimden 1. August Smart Lock Speaker Replacement: adım 3, 3 resimden 2. August Smart Lock Speaker Replacement: adım 3, 3 resimden 3.
    • Warm up the iOpener.
    • Do not place the iOpener in microwave for more than 30 seconds.
    • Place the iOpener heating pad over the speaker and let sit for a few moments.
    • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
    FixBot'a Sor
    Yorum Ekle
  4. August Smart Lock Speaker Replacement: adım 4, 2 resimden 1. August Smart Lock Speaker Replacement: adım 4, 2 resimden 2.
    • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
William Fink
841 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G6
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 1,887
