Giriş
This guide will teach you how to replace the speaker that are located within the device. The speaker can malfunction causing you to not hear the proper sounds from the lock.
Neye ihtiyacın var
Flip the device so the back cover is facing you.
Undo the latches on both sides to remove the metal cover.
Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
Bir başkası bu kılavuzu tamamladı.
