Neye ihtiyacın var
Zuerst sicherstellen, dass der Laptop ausgeschaltet ist. Entferne den Akku.
Mit einem Plastikwerkzeug die schmale Zierleiste entfernen.
Vorsicht beim Zusammenbau am Ende: Die Zierleiste kann leicht zerbrechen, da sie aus dünnem, weichem Plastik gemacht ist.
Mit der Spitze oder dem flachen Ende eines Spudgers die Verbindung entriegeln, die das Flachbandkabel der Tastatur am Logic Board befestigt.
Das Flachbandkabel herausziehen, nicht nach oben ziehen.
Beim Zusammenbau das Kabel mit einer Hand einstecken und festhalten, dann mit der anderen Hand die Verbindung verriegeln. Wenn man das Kabel zu früh loslässt, kann es wieder aus dem Anschluss herausrutschen.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
32 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
7 Yorum
I had to take my laptop apart to fix broken hinges which had been put in at factory was to stiff and it had cut the power connector inside. I replaced the power connector woth a new one and made a few little repairs, put everything back together but the keyboard did not work. After watching this video I redid the ribbon connection under the keyboard more carefully and and it works great. Thanks for posting this video. It was very helpful. This was my first time to work on a Laptop. Feeling great about my first laptop home repair.
What did you do about the hinges ? This one on my machine is to tight and broke ?
TIPS
There is a gold Torx male part located at F6.
You will have a hard time prying up there.
That's the worst issue.
There are tabs you will break off at F1, INS & HOME.
I broke two being careful.
You could hot glue in place if necessary.
DON'T BREAK the tabs on the ends of the lid.
Those keep it in place.
I thought the ribbon might be a stupid design like GE digital phones, not so.
Pop the connector using your fingernail.
The ribbon slides into place.
great design ...
Test & good to go ...
This was helpful thank you now my keyboard works
