Ana içeriğe geç
Automatic Tommy 20 Ammo Drum Replacement
Neye ihtiyacın var
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: adım 1, 2 resimden 1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: adım 1, 2 resimden 2.
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: adım 2, 3 resimden 1. Automatic Tommy 20 Ammo Drum Replacement: adım 2, 3 resimden 2. Automatic Tommy 20 Ammo Drum Replacement: adım 2, 3 resimden 3.
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: adım 3, 3 resimden 1. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: adım 3, 3 resimden 2. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: adım 3, 3 resimden 3.
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: adım 4, 1 resimden 1.
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Moira Foster
419 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-22, Maness Fall 2014 Cal Poly, Team 6-22, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G22
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 794
