Ana içeriğe geç
  1. 1. Turn on the autosampler. Screen will read "...STANDBY..." 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
    • 1. Turn on the autosampler. Screen will read "...STANDBY..."
    • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
    • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
    • 3. Use arrows to find "EVENT MARK". Press the "ENTER/PROGRAM" button.
  2. 4. Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button. 5. Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button. It is critical this setting is configured in order for the sensor node to operate the autosampler!
    • 4. Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
    • 5. Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
    • It is critical this setting is configured in order for the sensor node to operate the autosampler!
    • 6. Use arrows to find "EXIT CONFIGURATION." Press "ENTER/PROGRAM" button. This will bring up the screen "...STANDBY...
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Brooke Mason
2.385 İtibar
15 adet Kılavuz yazıldı
Takım
Open-Storm Open-Storm üyesi
Community
15 Üyeler
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 41
