Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Neye ihtiyacın var
1. Check the website for that node to make sure node has sent a reading in the last hour.
2. Contact the Real-Time Water Systems Lab to update the sampling frequency to every 5 minutes to make testing easier.
3. Disconnect the plug to the solar panel (yellow circle).
Then, grabbing the green connector, pull the battery connector from the solar charge controller (blue arrow).
4. Disconnect the plugs for the autosampler battery.
5. Disconnect the connector that plugs into the battery port of the sampler.
Now we will trigger a sample from the autosampler to confirm the sampling works.
7. Press the "MANUAL SAMPLE" button and then "ENTER/PROGRAM".
8. Confirm there are no breaks in the wiring between the interface board the autosampler. See this tutorial for more details.
9. Make sure the jumper is on so that the LEDs will light up during the test.
10. Plug the red and black jumper wires into the node battery terminal plug. This should turn on the yellow LED.
11. Touch the white jumper wire to the red wire then the white wire until the bottle count goes to zero. The blue LED will light up after each connection.
Bir başkası bu kılavuzu tamamladı.
