Ana içeriğe geç
Autosampler Reset for Node Triggered Sampling (For Old & New Versions)
Neye ihtiyacın var
  1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: adım 1, 2 resimden 1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: adım 1, 2 resimden 2.
    • To enable manual mode, flip the switch to "Manual Mode"
    • LCD screen will turn on
  2. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: adım 2, 2 resimden 1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: adım 2, 2 resimden 2.
    • Press On then press Start Sampling
    • Press Enter
  3. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: adım 3, 3 resimden 1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: adım 3, 3 resimden 2. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: adım 3, 3 resimden 3.
    • Press the number of the bottle you want to sample on
    • Press Enter
    • LCD should now show which bottle it will take a sample in
  4. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: adım 4, 2 resimden 1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: adım 4, 2 resimden 2.
    • To enable autonomous mode, flip switch to "Node Trigger Mode"
    • LCD should turn off
    • If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
Sonuç
Now the sampler is ready to be triggered remotely by an open-storm sensor node.
Bir başkası bu kılavuzu tamamladı.
Brandon Wong
502 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 410
