Ana içeriğe geç
Axa Security Greenline bicycle lamp disassembly
Neye ihtiyacın var
  1. Axa Security Greenline bicycle lamp disassembly, Disassembly of Axa Security Greenline bicycle lamp.: adım 1, 1 resimden 1.
    • To open the lamp housing, you first have to remove the black cover at the front. This is the part that covers the screws that you have to get at first. Unfortunately, it is glued in some places. It is best to use a sturdy plastic tool so that the plastic does not break (as it did with me).
    • Also, start from the side rather than from the front to avoid scratching the lens.
  2. Axa Security Greenline bicycle lamp disassembly: adım 2, 1 resimden 1.
    • Remove the four screws that hold the lens to the LED heatsink
  3. Axa Security Greenline bicycle lamp disassembly: adım 3, 1 resimden 1.
    • This shows the four screws that hold the plastic back cover to the center metal frame. Remove them as well.
  4. Axa Security Greenline bicycle lamp disassembly: adım 4, 1 resimden 1.
    • The black one should be soldered to "GND"
    • The red wire belongs where it says "Bat.+"
    • Now you can pull out the main circuit board. Be careful not to tear off any more of the tiny wires. Also be careful not to short-circuit the LiPo battery pack (1s2P 1000mAh).
    • The wires with transparent insulation are for the charging connection. When you have soldered everything back into place, slide the circuit board back into place on the top of the battery. Pay attention to the tiny plastic part of the on/off switch, which should be in its place in the orange silicone cover and will easily fall out.
    • Don't force the board into place, or you'll probably rip another cable. Once everything is in place, test the lighting (test the light AND the charging process!) before screwing everything back together.
    • Finally, glue the black lens cover back on. Don't use too much glue in case you need to open the lamp again later. Also, be careful not to touch the lens with glue on your fingers! A piece of tape works well as a protective covering until the glue has dried.
Sonuç
Repeat the steps in order to reassemble your device.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Martin Kuklinski
1.150 İtibar
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thanks Martin! Using your guide I was able to fix a loose wire from the battery after a small drop on the ground.
Bart Ramharter - Yanıt
Thank you very much! The micro switch is broken and now I can fix it, I thought everything was just glued together and not repairable.
Christoph Hafner - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 54
Her zaman: 2,079
