Ana içeriğe geç
Axe Empire 2.0 OLED Board Replacement
Neye ihtiyacın var
  1. Axe Empire 2.0 OLED Board Replacement, OLED Board: adım 1, 2 resimden 1. Axe Empire 2.0 OLED Board Replacement, OLED Board: adım 1, 2 resimden 2.
    • Use an Allen key to remove four total screws.
    • 2.5 mm screws.
    • 1.2 mm screw.
  2. Axe Empire 2.0 OLED Board Replacement: adım 2, 3 resimden 1. Axe Empire 2.0 OLED Board Replacement: adım 2, 3 resimden 2. Axe Empire 2.0 OLED Board Replacement: adım 2, 3 resimden 3.
    • Press and hold the release button while lightly pulling the spring bolt out.
    • If the spring bolt has not been serviced with lube after a long time you might need to pull harder. This is a great time to lube the spring bolt.
  3. Axe Empire 2.0 OLED Board Replacement: adım 3, 3 resimden 1. Axe Empire 2.0 OLED Board Replacement: adım 3, 3 resimden 2. Axe Empire 2.0 OLED Board Replacement: adım 3, 3 resimden 3.
    • Remove the two main screws using a 2.5 mm Allen key to separate the air transfer plate from the frame.
  4. Axe Empire 2.0 OLED Board Replacement: adım 4, 2 resimden 1. Axe Empire 2.0 OLED Board Replacement: adım 4, 2 resimden 2.
    • Remove the screw using a 2.5 mm Allen key and remove the foregrip from the frame.
  5. Axe Empire 2.0 OLED Board Replacement: adım 5, 2 resimden 1. Axe Empire 2.0 OLED Board Replacement: adım 5, 2 resimden 2.
    • Use a 1.2 mm Allen key to remove the screw, and remove the cover to expose the OLED Board.
  6. Axe Empire 2.0 OLED Board Replacement: adım 6, 3 resimden 1. Axe Empire 2.0 OLED Board Replacement: adım 6, 3 resimden 2. Axe Empire 2.0 OLED Board Replacement: adım 6, 3 resimden 3.
    • Remove the last screw with a 2.5 mm Allen key to loosen the OLED Board.
    • Use a pick tool to carefully remove the battery and OLED Board together out of the foregrip.
    • Wear gloves in case battery is defective and leaking acid.
  7. Axe Empire 2.0 OLED Board Replacement: adım 7, 2 resimden 1. Axe Empire 2.0 OLED Board Replacement: adım 7, 2 resimden 2.
    • Disconnect the battery from the OLED board.
Sonuç
Christopher Ramos
345 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 255
