Giriş
Use this guide to replace a malfunctioning OLED Board in your Axe Empire 2.0 Marker.
The OLED Board is a screen on a paintball marker that allows you to see text and graphics of your devices settings. A malfunctioning OLED Board can cause your marker to make you unable to modify your devices setting, view important information, or unable to turn the device on at all.
A battery leaking battery acid is unsafe so I recommend you wear gloves when getting in the inside of your Axe Empire 2.0.
In step 1 of this guide, you will need to use an old toothbrush and possibly a rag. Since this device is used with players with other people and constantly getting hit with paint, cleaning out the Allen heads will ensure the correct Allen keys will fit.
Neye ihtiyacın var
Use an Allen key to remove four total screws.
2.5 mm screws.
1.2 mm screw.
